PID control of heating element feedback timeout error
I have a problem about feedback and PID control. I am having timeout error.
Lakeshore 336 temperature controller
K182 nanovoltmeter
2 K type thermocouples
2 25ohms heaters
In my vi, there are two heaters control. Output's 1 is controlling the heater output 1, and Output's 2 is controlling the heater output 2. Both heater start heating, I guess they can start heating in order, 1sec differense for example, but reading should be simultaneously. Timeout error I am having attached.
I am not good at Labview, but i need to write this software. So, I am attaching my vi.
heaters will go to specific temp. and then measurement will be done, then the heaters will go to next set point as can be seen in vi I attached.
thanks in advance....
(2,633 Views)
Hey becidea,
I found a Knowledge Based Article: Why do I Receive Timeout Error -1073807339 on VISA Read or Write? for you to look at. Give this a shot and see if it can help out. Please keep us posted of your progress.
Ricky V.
(2,604 Views)
This can be my problem's solution bu I checked this and I applied both things seperatley. I guess I have a mistake but I don't know from where!. thanks again. I will keep you inform if I found  the solution.
(2,573 Views)
