PMU usage in cRIO
Thank YOU!!
Message 21 of 30
(2,195 Views)
can anyone help me with the example of synchrophasor vi given in labview?
Message 22 of 30
(2,188 Views)
Hi suryas,
What is your problem with this example VI?
Message 23 of 30
(2,182 Views)
Its too complex. Is there any pdf explaining that example.
Message 24 of 30
(2,176 Views)
Hi suryas,
if its too complex you need to tackle it step by step!
Did you take all the LabVIEW basics?
Do you have a full understanding of the underlying physical problems?
Do you know how to use your hardware in general?
Did you examine simpler example VIs?
Are you talking about VIs from this toolkit? There are help entries for each function! And a lot of IEEE standards are listed, you might read them too… 😉
I don't think there is a PDF explaining an example VI which in turn explains how to use LabVIEW and hardware…
Message 25 of 30
(2,174 Views)
how to reduce the slice luts in FPGA
Message 26 of 30
(2,129 Views)
Hi suryas,
try this!
Message 27 of 30
(2,122 Views)
Hi
i Am getting ripples from 9201 input module not getting pure sine wave.
Message 28 of 30
(2,105 Views)
i am using cRIO 9075 and analog input module 9201. fro the 1st time i got pure sine wave from the 9201 but after that i dint get the pure sine wave. full ripples and also some time FIFO read error -50400.
can anyone help me with this issue.
Message 29 of 30
(2,151 Views)
Hey guys, i want to use my cRIO - 9064 as phasor measurement unit. I have NI 9467 GPS module and NI 9225 analog input voltage module for that. I wanted to use example vi (synchrophasor measurement) for that and i made some modifications on it in order to design my cRIO as PMU. I omitted the current input part (NI 9246) and digital input/output (NI 9402) , replaced NI 9242 with NI 9225. After modifications, i could not measure the input voltage accurately, but i could measure the frequency of input voltage accurately. I could not figure out the problem. So could you please help me about that. I added my VIs if you sould want to see.
Thanks a lot in advance.
Şamil
Message 30 of 30
(1,720 Views)
