Padding clusters to match C structures
Well, NI ETS and Win32 are the same as far as such details are concerned. LabVIEW uses always byte packing on these platforms. So if your DLL is compiled for default alignment you will have to make sure that you create clusters with proper padding built into.
For 64-bit platforms it always uses the default alignment for that platform, which as far as I know is 8 byte for all systems you can run LabVIEW on nowadays (Windows 64-bit, Linux 64-bit, Mac OSX 64-bit). For these platforms you should not need any special padding in the clusters to make it work with your DLL. Incidentally the padded clusters should also work on these platforms since Win32 default alignment is also 8 byte.
The only one I'm not sure about is Linux 32-bit and Mac OSX 32-bit. But for the latest versions of LabVIEW they are not supported anymore so it is kind of a moot point already.
Rolf Kalbermatter
My Blog
Message 11 of 16
(800 Views)
@schddc wrote:
I was hoping there was a better way to do this.
There is, as I originally told you.  Write a clean and simple API so interfacing with your dll is easy from any wrapper in any language.  Do not require those wrappers to deal with “packing”.
Message 12 of 16
(769 Views)
@drjdpowell wrote:
If you are the developer if this c dll then I suggest you provide functions to write/read parts of your structure, then only handle the structure in LabVIEW as an integer pointer passed between these functions.  Then details about packing never come up.
I take it you mean instead of sending function(*struct), you send function(part1, part2 ... partn)? That's a solid and easy solution.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 16
(755 Views)
/Y
Oh, you can and should use function(*struct), just never expect the wrapper code to modify or read the parts of struct.  They should just pass a pointer between your API functions.   So, for example, one can have:
GetParam(*struct)
Setting=ReadMySetting(*struct)
SetMyOtherSetting(*struct,OtherSetting)
Implemented in LabVIEW, *struct would just be a pointer-sized Integer.  So GetParam(Int32 or Int64)
Message 14 of 16
(753 Views)
I don't have to much flexibly to change the C dll anymore as it's already been released and in use. I can add new APIs but I prefer not to have any breaking changes if possible.
I only have 1 function which has a prototype of GetCapabilities(int, *struct) . The structure has several nested structures. The C dll provides an interface to physical hardware. This function returns all of the device capabilities. It's something an end user would call once and then they would make conditional checks based on the number of channels and types of features of their specific hardware model.
Message 15 of 16
(744 Views)
Simple then.  Just get going and add the API functions that do those "checks".  They would be very simple functions and don't involve any breaking changes.
Message 16 of 16
(728 Views)
