Problem in acquiring signal from LVDT.
Hi
I have connected Lvdt to SCXI module 1540 with TBX 1315 , my PC is detecting hardware but the problem is i am not getting sensible output in labview.
(2,805 Views)
What are you getting ?
What did you expect ?
What does your code look like ?
(2,780 Views)
Do you use a counter while acquisition in the code ?
(2,769 Views)
Just am getting some signal in graph indicator , that value comes even if i didn't switched on SCXI
I expected change in value as i move the arnature of LVDT , But when i move that either forward or backward it gives same value.
I confirmed LVDT by connecting to digital meter ,their its giving sensible output.
mpsingh
(2,758 Views)
no i didn't used counter i just connected DAQ assistant to graph indicator .I don't no about that counter
mpsingh
(2,757 Views)
Sorry to piggyback on this topic, but I am having a similar situation.
I am new to using LVDTs but have used labview several times before. How would a counter help in understanding if there was a problem in the acquisition? I believe that my connections are correct, but the output signal does not seem to fluctuate with movement/displacement of the sensors like I believe it should, even in automated explorer.
What would others recommend the best measurement setting be in, a generic voltage measruement?
Thank you for any help you could offer,
Arthur J.
(2,707 Views)
