Producer Consumer Pauses at high rates
Accepted by topic author skinnert
@skinnert wrote:
I can only mark 1 thing as a solution so I did that. The McDuff
You can mark multiple posts as solutions if desired.
@skinnert wrote:
I like the DAQ-MX logging quite a bit. I haven't yet figured out how to enable/disable it since I don't want it recording all the time and also how to add additional header information to the resulting TDMS files... I've got some research to do but I'll get there.
If you use the Event Structure template I posted earlier, it is an easy mod. In fact I just made the mod. See below and attachment. Adding additional header information is not currently supported; you can do this, but it needs to be after the acquisition. You can kudo this idea.
Message 21 of 22
(345 Views)
Multiple solutions accepted and Kudos given! Thanks!
Message 22 of 22
(314 Views)
