Queues in User events
       I have a main vi which uses user events to communicate with child vi's. The problem, At the exit of the program Main vi (Parent vi) generates user event to save settings of all the child vi's and child vi's send the settings, If i have 10 child vi's i recieve  settings of only one child vi and some emty variant. So, how to avoid this kind of a problem using queues, If any efficient solution please to advice.
Message 1 of 9
(3,380 Views)
Events have queues.  So that isn't your problem.  You will need to share some code if you want us to help you diagnose this error.
GCentral
Message 2 of 9
(3,377 Views)
        I had a question, for eg: if i have 50 child vi's on FP, and if i generate a user event from main Vi, which child vi will respond first? When i generate user event in Main vi, how does actual reach to all child vi, I mean to say one by one or simultaneous?
Message 3 of 9
(3,368 Views)
Assuming everybody is registered for the event, everybody will get the event at about the same time.
GCentral
Message 4 of 9
(3,345 Views)
Thanks a lot, ok. In the above example if 50 child gets event at the same time. How do v actually recognise all 50 response from child vi's? So, what's the method to get response one by one from all child vi's ?
Message 5 of 9
(3,325 Views)
You could generate response events, or if you want to wait for all to finish you can use a Rendevouz e.g.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 9
(3,311 Views)
Could you please explain me in detail. Since, child vi's are the clones of original vi, how can v actually generate response event?
Message 7 of 9
(3,293 Views)
Ok, that doesn't make any architectural sense.  You have a single instance of a VI closing all of the other instances of the same VI?  So what makes that one so special?
GCentral
Message 8 of 9
(3,266 Views)
Your descriptions are very confused. Can you show us some code and explain specifically what it is that you want to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 9
(3,246 Views)
