Read multiple Files
I have a VI which can read LMV files and perform calculations based on the LMV files. I put them in a for loop or a while loop and I am able to read them continuously.
When I run the program, I have to choose an LMV file every time the calculation is done. What I mean is , once I run the program, I am asked to choose a file. LabVIEW performs some calculations on it and then once it is done, I asks me to choose the next file again and this continues.
However what I want to do is to select multiple files at once and let LabVIEW do the calculations for all of them without me having to choose the file again and again. Please do help me with this. Thanks in advance. I have also attached the VI.
(4,868 Views)
You can use Filename terminal.
One case, make array of path and select manual. Or form array programmatically
(4,857 Views)
Accepted by Akaash_Dragon
The built-in "File Dialog" VI can be used to select multiple files. In the "Configure File Dialog" window, uncheck the box marked "Limit selection to single item". Then you can select multiple files in the same folder easily. The selected files' paths will be in an array, which you can auto-index in your For loop.
(4,849 Views)
I did try that, however the problem is I still have to keep choosing the files again and again. LabVIEW doesn't automatically choose the files which I had selected in the dialogue box.
(4,810 Views)
Is it the "Write to Measurement File.vi" that's asking you to choose a file each time? You'll have to connect something to its "Filename" input as well if you want to avoid that. Can you automate the generation of the filename to write in each loop iteration, based on the filename that was read?
Never mind, I see the problem. In the properties for your "Read from Measurement File" you need to uncheck the "Ask user to choose file" box.
(4,804 Views)
You didn't wire up the path in the Write To Measurement File.
GCentral
(4,803 Views)
Thanks a ton! It worked
(4,798 Views)
