Repeated calls to acquire semaphore
The help file for acquire semaphore states: "Acquiring the same semaphore twice without an intervening call to Release Semaphore generally results in incorrect behavior, such as corrupted data values."
I thought that semaphores could be created with a size greater than 1, thus allowing the semaphore to be acquired multiple times before the semaphore is released. What does setting size to a value other than 1 do if the semaphore must be released before each subsequent call to Acquire Semaphore?
Jason
Jason Rolfe
(2,511 Views)
Hi Jason,
Normally semaphores are used to prevent multiple calls to for example an non-reentrant I/O-drive, hence the description in the help file.
There are no limitations in the actual semaphore VIs that prevents you from using a size greater than 1, as long as you specify it with the "Create Semaphore.vi".
Philip C.
National Instrument
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,511 Views)
