Representing the state of many buttons by a string
I have sixteen switches.
I need to read the status of the switches and form a string as per this format :
<S0,S1,S3........S15,> and pass it via a Serial link to a microcontroller  which will strip the switch status from the string and do something with it.
I created a small sample with four switches and managed to do what I want.( looks like a college project !)  Of course I should have used a FOR loop but never could do it - it has a Concatenation tunnel option but never understood how it works.
Any better method ?
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(2,737 Views)
Maybe this will give you some ideas:
(2,727 Views)
Accepted by topic author MogaRaghu
Comments:
  • Do not use a Timed Loop -- they are designed for (and should probably only be used for) LabVIEW Real Time code running on LabVIEW Real Time Processors.
  • Whenever you need to do the same thing to multiple Controls (or numbers), you should think "Arrays" and "For Loops".
  • Whenever you need to build Strings, you should think "Format into String".
I was going to attach a Snippet and show you how to do this, but you'll learn far better if I tell you how to do it, and then you do it.
  1. Take 4 Booleans and wire them to Build Array.
  2. Make a For Loop and bring this Array in via an Indexing Tunnel.
  3. Also create a Shift Register (to hold the String), and initialize it with "<" (from outside the For Loop.
  4. Inside the Loop, drop a Format Into String function and wire the Shift Register into Initial String and Resulting String.
  5. Wire the Boolean (from the Array) through a Boolean-to-0,1 function to the lower input of Format Into String.
  6. Edit Format String (right-click Format Into String) by adding a "," after the default %d.
  7. On the output side of the For Loop, use one more Format Into String (with Initial String from the Shift Register and the string ">" on the lower input.  The default Format String (%s) is fine.
That does it!  Very compact, very simple, easy to generalize (for other types of inputs), etc.
P.S. -- I also like GregoryJ's solution.  I tend to stay away from the LabVIEW "Spreadsheet" functions, however ...
(2,711 Views)
Any better method ?
gregoryj beat me to it. However, from your format descriptor, it looks like you need a trailing comma after the last status. This would be the format string to add that last comma
(2,709 Views)
Thanks to all three who responded.
I liked Bob's concept .. it does it quite nicely.  Attaching the assignment !! Never really had a an opportunity to use the Boolean-1/0 function. Cute .
Raghunathan
(2,655 Views)
