Retain Last Value of Output (Indicator)
Dear Sir,
I want to Retain the Last Value of my Output (Indicaotor) when i re-run the program. But now if  last value was true when i closed the VI it is changing to False if  i open and Run the VI.
e,g If last Value of OUTPUT is True when i closed the VI, it should be TRUE when i re-open and Run the VI
      If last value of OUTPUT is Flase when i closed the VI, It should be FALSE when i re-open and RUN the VI
(2,254 Views)
