Return array from VBA Sub to Labview with Excel Run Macro VI
Hi everybody,
I try to use the Excel Report - Run Macro VI with a VBA Macro (My_Macro) structured as follow :
Sub My_Macro(A, B, C, D)
    Dim Chart_name() As String
End Sub
Function blabla()
End Function
In the code I build an array of strings and I would like this array to be returned to Labview. I do not know how to do that.
When I write Sub My_Macro(A, B, C, D) As String the code does not run anymore.
Please could you help with this.
Cheers,
(3,415 Views)
Can you post your VBA code that builds and returns the array?
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(3,404 Views)
Assuming this is your VBA code in a workbook called Book2.xlsm:
Function Macro1()
    Dim StringArray(1 To 2) As String
    StringArray(1) = "Test"
    StringArray(2) = "Test3"
    Macro1 = StringArray
End Function
This Labview code should run and return an array with those values.
aputman
(3,393 Views)
Hi aputman,
Thank you for your answer.
I found on the internet that it was not possible to return something with Sub() in VBA so I used Function() instead ans it works.
(3,368 Views)
