10-15-2023 10:24 AM
Hi I am developing a test system using Crio-9023 which a legacy Chassis controller and supports Labview and Drivers only till 2019. We are using it since it is readily available. We are planning to use it for development & Testing however we are planning to procure a Crio with latest support. So the code will be eventually Migrated to Labview 2023.
I am curious if this approach is worth the time or we should wait and start development only after procuring the new hardware.
Will the CompactRio drivers create any issue while migrating from 2019 to 2023 versions.
CompactRio, RT and Report Generation Toolkit are major components of the application we are developing. will any of these components create conflict while upgrading?
10-15-2023 12:31 PM
Most likely you can get it done easily via Moving Examples to a Different FPGA Target, but I don't want to say it is 100% trouble-free without knowing all the modules and libraries being used.
