Run with Resampling(FIR) and memory is full error
I read the UDP I/Q raw data package from a receiver ,then do FM demodulation and resampling.
I try to run my program.
If I use "FIR filter" option for resampling, it will show a error message:"Memory is full...".
If I use others like "linear", "spline", it will not show any error message.
I do not know why the resampling using fir filter will show this error message.
Hope some of you guys (or girls) are able to help me.
thanks!
Howard
(2,414 Views)
If you probe this value, what is the number?
Benoit
(2,381 Views)
I probe some value :
(2,362 Views)
That's why.  4.29 billion would be a huge array.  You don't have that much memory.
Either your original array is too large, or more likely you are trying to re-sample it into too many additional elements.
(2,358 Views)
