Running Labview 8.6 vi will not run in 2010
I am trying to run a VI that has worked in Labview 8.6 and trying start or run in 2010
will not function and stops 2010 from working and removes all from memory
The llb loads ok but when the main vi is started it stalls for a few seconds then 2010 quits
This llb in 8.6 works fine as it has for over a year
The llb can be saved to 2010 in a file and called again
but still will not run
all the vi's in the llb run separately and are saved in 2010 to a new dir
but the llb will not start
What is missing here
Message 1 of 9
(2,873 Views)
Did someone do something silly such as saving functions from vi.lib into the llb?
Quite frankly, if you can extract the VIs into a folder and it runs, leave it that way. An llb has been obsolete for several years and serves no useful purpose anymore.
Message 2 of 9
(2,866 Views)
Information. As in what your VI is doing. All you've said is that you have a VI that runs in 8.6 but not in 2010. That tells us nothing, since 2010 can load and run old code just fine in the vast majority of cases. Exceptions are usually due to deprecated functions or changed functions, or drivers that were being used that do not support 2010.
How To Ask Questions The Smart Way
Message 3 of 9
(2,865 Views)
Please see section
How To Answer Questions in a Helpful Way
Message 4 of 9
(2,843 Views)
The main vi will not run in 2010
it works in 8.6
file in a dir or not
llb or project or exe
Message 5 of 9
(2,840 Views)
That kind of response is not going to help you get any answers from the forum.
What kind of help do you expect to get when you post a question that has no meaningful information in it?  All you say is something will not start.  What is it doing instead?  Do you get error messages?  What do the VI's do?  Is there anything special going on like toolkits or add-ons that you may not have installed with 2010.
If you want meaningful help, then you need to post meaningful questions with useful information and that link was S-mercurio's way to guide you how to ask a question.
Message 6 of 9
(2,836 Views)
A list of vi are saved in a llb on a share drive that development people call every day
There are thousands of program that are structured in this way with a number of individuals working with them
there is no way they can be brought up to a current level
they just run good and give data for sites all over the world
Most programs were developed in 8.2, 8.6 and some new now in 2009
I said 2010 as this the latest before we go to 2011
This vi will also not run in 2009
 Driver There are a few which the vi never gets to that part
it just will not start in 2009 or 2010
Message 7 of 9
(2,834 Views)
Let ME guess,
(because the OP will not provide details)
So you are working with the configuration file palatte functions!  the Config file palatte changed between 8.6 and 2009.  You must use one API or the other, mix and match does not work!
(~~~oh magic 8-ball, did the OP use the config file API? and mix while upgrading?~~~~)
"Yes, but maybe it depends"
Thank you magic 8-Ball
"Should be" isn't "Is" -Jay
Message 8 of 9
(2,826 Views)
See if it tells you whether I'm going to be rich. Smiley Very Happy
Message 9 of 9
(2,812 Views)
