06-22-2009 11:01 AM
where can I download the Simulation Interface Toolkit (version 5.0.1)? Version 5.0.0 is installed on the system but I can't find the update to 5.0.1 neither in MAX nor on the website.
Regards Michael
Solved! Go to Solution.
06-22-2009 11:28 AM - edited 06-22-2009 11:29 AM
Hi Michael,
Good afternoon and I hope your well today.
If you have an NI Profile and can access to the Resource Center you can download the patch.
(Link may not work, try http://www.ni.com/support/ then on the right-hand side select Support Services>>Services Resource Center)
Software Upgrades and Maintenance Releases>>NI LabVIEW 8.6.1 Toolkits
Hope this helps,
06-24-2009 03:41 AM
Hi James,
thanks for your reply.
I didn't register properly, but now I'm able to download the toolkits.
Why is it that I can only download version 5.0 although a readme of version 5.0.1 exists?
Regards Michael
06-24-2009 05:02 AM
Version 5.0.1 is installed but version number in MAX is still 5.0.0.
Regards Michael
06-24-2009 06:45 AM
Hi Michael,
Thanks for the update.
The download for 5.0.1 is on the site as well.
There is a known issue that 5.0.1 appears in MAX as 5.0.0. CAR ID# 161743
Thanks, and can I ask for some Kudos 🙂 Have a nice day.
