04-13-2010 03:19 PM
I'm seem to be having a problem with a SPI write using the NI-8451 POD with a SPI clock of 1MHz. The read is only 8usec after chip select go low but the write is 44usec after the chip select go low ( I have attached scope pictures). I have taken and earlier version of this write subVI and the only change was from writing a 32 bit registers to an 8 bit registers which should have speeded it up. Has anyone seen this before, I don't have this much delays in the earlier write subVI and it is a remake of the example (SPI advanced write script). I'm using LabVIEW version 8.0 I also included the spi write script block diagram for your review. Let me know what else you'll need to help diagnose this delay problem.
Gary Tyrna
04-19-2010 10:23 AM
