Saving current time during measurement
I would like to save time when i started measurement. is it possible to first saving data and time, then showing them on graph, on y axis datas, on x axis, time(not current time, but time when i saved during measurement.)
thanks a lot.
Message 1 of 9
(3,192 Views)
Hi alican,
yes, that possible (all of it). You have to program it! 😄
Hints:
- depending on your file format you might want to convert timestamp to string using FormatDateTimestring
- you might want to save your data too, not just the timestamp 🙂
Message 2 of 9
(3,178 Views)
If you get your data in the waveform format, have a look at the t0 value 😉
If wire the wfrm to a graph, the x axis will start with that t0 value (unless you don't tell to ignore the timestamp)
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 9
(3,170 Views)
hi
i made this program, it produce random number and save it with current time.
how i will plot in in second program, i get problem about accesing one coloum, of array seperately. i put things what i did, maybe solution is so simple but i cant see.
thanks in advance
Message 4 of 9
(3,155 Views)
hi again,
a bit prograss, but there i problem to read time value from text.
time is like 16:34:23 but it read it like 16,000. what kind conversion do i need to do?
thanks.
Message 5 of 9
(3,144 Views)
i was looking at your programs and trying to make sense of it all...i cleaned it up to a compact version of what you are trying to do. save the file as a .CSV delimeter. see if it makes any sense?  Smiley Wink
Spoiler
Message 6 of 9
(3,105 Views)
do you know is it possible to see, more time datas on X axis, not just 3 points but more..
best regards
Message 7 of 9
(3,066 Views)
best regards
yes, display format time x-axis drop down box for custom time format at the graph properties...
Message 8 of 9
(3,049 Views)
Time in Excel has a different epoch (base date) and scale than LabVIEW uses.  Use the Time to XL.vi found here (don't forget to vote)
"Should be" isn't "Is" -Jay
Message 9 of 9
(3,041 Views)
