Search information on XML
I have the following XML:
<soap:Envelope xmlns:soap="http:OcultURL">
    <soap:Header/>
    <soap:Body>
        <ns1:OUTPUT_DATA xmlns:ns1="http:OcultURL">
            <OUTPUTList>
                <OUTPUT>
                    <SalesOrderNumber/>
                    <SalesOrderItem/>
                    <OrderNumber/>
                    <WBSElement/>
                    <MaterialNumber>32478155</MaterialNumber>
                    <AlternativeBOM>01</AlternativeBOM>
                    <Plant>0</Plant>
                    <Usage>1</Usage>
                    <Status>01</Status>
                    <ChangeNumber/>
                    <MaterialList>
                        <Material>
                            <ItemNumber>0730</ItemNumber>
                            <Category>L</Category>
                            <Component>43731</Component>
                            <Quantity>1.000 </Quantity>
                            <UnitOfMeasure>UN</UnitOfMeasure>
                            <SortString/>
                            <RelevantToCosting>X</RelevantToCosting>
                        </Material>
                        <Material>
                            <ItemNumber>0740</ItemNumber>
                            <Component>5367137</Component>
                            <SortString/>
                        </Material>
                        <Material>
                            <ItemNumber>1500</ItemNumber>
                            <Component>573123</Component>
                            <SortString/>
                        </Material>
                        <Material>
                            <ItemNumber>1550</ItemNumber>
                            <Component>1234374</Component>
                            <SortString/>
                            <CadIndicator>X</CadIndicator>
                        </Material>
                        <Material>
                            <ItemNumber>1551</ItemNumber>
                            <Component>123456</Component>
                            <SortString/>
                        </Material>
                        <DocumentList/>
                        <ClassList/>
                        <TextList>
                            <Text>
                                <ItemNumber>0009</ItemNumber>
                                <Category>T</Category>
                                <UnitOfMeasure>ST</UnitOfMeasure>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText1>* * * ACESS DENIED  * * *</InputText1>
                                <InputText2/>
                            </Text>
                            <Text>
                                <ItemNumber>1499</ItemNumber>
                                <UnitOfMeasure>CJ</UnitOfMeasure>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText1>* * * OCULT INFORMATION * * *</InputText1>
                                <InputText2/>
                            </Text>
                            <Text>
                                <ItemNumber>2199</ItemNumber>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText1>* * * TEST NUMBER 2 * * *</InputText1>
                                <InputText2/>
                            </Text>
                            <Text>
                                <ItemNumber>2599</ItemNumber>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText1>* * * TEXT TEST * * *</InputText1>
                                <InputText2/>
                            </Text>
                            </Text>
                        </TextList>
                    </MaterialList>
                    <PlantAssignmentList/>
                </OUTPUT>
            </OUTPUTList>
            <ErrorList/>
        </ns1:OUTPUT_DATA>
    </soap:Body>
</soap:Envelope>
I need to find the ItemNumber of InputText1 = * * * OCULT INFORMATION * * *
After that I need to check in MaterialList which Material corresponds to the digits. Ex: If ItemNumber of * * * OCULT INFORMATION * * * is 1499, I need to find the Materials that have ItemNumber of the same "Family", in this case: 1500, 1550, 1551
Can you help me to do that? I'm having a hard time with this
(304 Views)
LabVIEW has some good XML parsing VI's
But when I try to paste your XML into XML Notepad I get this error:
I don't really have the time to figure that out.
=== Engineer Ambiguously ===
(282 Views)
I'm sorry, i forgot to remove an tag that no needed
Here is the corrected XML
    <soap:Header/>
    <soap:Body>
            <OUTPUTList>
                <OUTPUT>
                    <SalesOrderNumber/>
                    <SalesOrderItem/>
                    <OrderNumber/>
                    <WBSElement/>
                    <Plant>0</Plant>
                    <Usage>1</Usage>
                    <Status>01</Status>
                    <ChangeNumber/>
                    <MaterialList>
                        <Material>
                            <SortString/>
                        </Material>
                        <Material>
                            <SortString/>
                        </Material>
                        <Material>
                            <SortString/>
                        </Material>
                        <Material>
                            <SortString/>
                        </Material>
                        <Material>
                            <SortString/>
                        </Material>
                        <DocumentList/>
                        <ClassList/>
                        <TextList>
                            <Text>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText2/>
                            </Text>
                            <Text>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText2/>
                            </Text>
                            <Text>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText2/>
                            </Text>
                            <Text>
                                <SortString/>
                                <ReferencePoint/>
                                <InputText2/>
                            </Text>
                        </TextList>
                    </MaterialList>
                </OUTPUT>
            </OUTPUTList>
            <ErrorList/>
        </ns1:OUTPUT_DATA>
    </soap:Body>
</soap:Envelope>
(240 Views)
Thank you for help, i get it the solution.
(232 Views)
