I am trying to measure a signal that has both a varying period and
varying duty cycle. I am currently using an extension of your
example VI entitled "Measure Buffered Semi-Period-Continuous.vi" with
"Samples to Read" set to 2 and a few more calculations in the while
loop. My problem alies in triggering measurements with my
particular multi-function daq board which is a PCI-MIO-16E-4 NI
device. While I can live with discarding the first measured
value, I would like to know if the measured semi period is a high value
(5 volts) or low value (0 volts). I attempted to use Measurement
I/O<<DAQmx<<DAQmx Trigger.vi but found out that it was not
compatible with counter measurements for my particular hardware.
If there is some way that I can either (A) start on a rising or falling
edge or (B) calculate the voltage of the incoming signal then this
would help me greatly in differentiating between the two semi period
measurements. While some of the other examples take into account
rising or starting edge startup, I have not been able to find an
example off hand that functions as well as the "Measure Buffered
Semi-Period-Continuous.vi" for signals with both varying period and
duty cycle. Any help in this matter would be greatly appreciated.
Nick
