03-04-2013 04:41 AM
Hi
I would like to be able to set the maximum and minimum values on the waveform chart's y-axis to a number that is defined by the user earlier in the program (in an earlier subvi) during run-time. I want to be able to use the "V to Torque" value and make that the maximum (and the inverse as the minimum) y-axis scaling on the graph. Is there any way to do this?
I have attached a screenshot of the relevant portion of the code. which currently only takes in the value into the graph and autoscales, which is not what I want.
Please note I am using Labview 8.6.
Thanks.
03-04-2013 04:51 AM
03-04-2013 06:06 AM - edited 03-04-2013 06:08 AM
Hi
I think that's it. Thanks!
If anyone else has the same problem, the property node I used was Y-Scale/Offset and Multiplier/Multiplier. I then had to right click the newly created node and change to write to input my variable.
Thanks again GerdW
