Setting Up Labview 7.1 with Tektronix TDS3034B
Hello
I saw that but I can't open the example
could you send me an example or tel me how I can connect the buffer read to a waveform
thanks
Message 11 of 23
(1,459 Views)
I can open the driver with 7.1. What exactly happens to you? Are you sure you have version 7.1? After you unzip it, there will be a tktds3k folder with a tktds3k.llb and tktds_u.llb. There are five top level examples in tktds3k.llb. There are some VIs in the _u.llb file that you will may need to refer to when opening VIs in the main llb.
Message 12 of 23
(1,455 Views)
when I open the example it tell me that I cant open it because it is newer than 7.1.
Message 13 of 23
(1,451 Views)
Go to here and click on the circled link. I just did it and it is a 7.1 file.
Message Edited by Dennis Knutson on 07-03-2008 06:11 AM
Message 14 of 23
(1,443 Views)
I found the driver on NI website (plug & play (project style)). Can't get it to work with ethernet. It looks like you don't have to do anything if you are using Serial port, but the problem is that I only have ethernet on the scope. I'm not really sure where to start. In the Visa Resource Name drop box, I changed the Visa Class I/O sessions to TCP/IP Inst. ( I did this in all subvis) and this did not help with anything. Any sugestions? where do I start?
Message 15 of 23
(1,235 Views)
Were you able to get it working in MAX? This should always be your first step (not trying to get it working in LabVIEW from the start). I read back through the post but I didn't see your answer to Dennis as to whether or not it's working in there.
Message 16 of 23
(1,217 Views)
I did, works great. In the future I will always look into MAX first.
Message 17 of 23
(1,213 Views)
I am using TDS3034B and the only module to connect this scope with PC labview is through LAN Ethernet.
I tried many things i could find from the internet and none of it solved my problem. NI MAX still not able to communicate with the scope.
1) I tried configure scope IP to 192.168.1.1.
Then, create TCPIP resource via MAX but can't when i used Auto-Detect or Manual Entry the host IP.
2) try to ping using cmd.exe and same thing happened. "could not find the host IP".
Anyone can help?
Message 18 of 23
(954 Views)
What is the IP address of your computer?
Message 19 of 23
(935 Views)
I am not sure my PC IP address.
But i did configure the local area connection's properties in TCPv4. I tried again just now. it showed unidentified network after i changed the IP to 192.168.1.2.  What does it mean?
Message 20 of 23
(920 Views)
