Setting Up Labview 7.1 with Tektronix TDS3034B
By the way, more background of my setup. i am directly connecting rear panel LAN port of Scope to PC LAN port by LAN cable.
Message 21 of 23
(482 Views)
@Telasdist wrote:
I am not sure my PC IP address.
But i did configure the local area connection's properties in TCPv4. I tried again just now. it showed unidentified network after i changed the IP to 192.168.1.2.  What does it mean?
That just means that Windows can't get a name out of a router to state what network it is on.  In this case, nothing to worry about.
If I am remembering the scope correctly, I think you also need to state who the host is in the settings.  Make sure that matches the IP address you set for the computer.
GCentral
Message 22 of 23
(458 Views)
Thanks for the help. I managed to connect it. it is due to LAN port faulty on the instrument. i changed the instrument and everything solved.
Message 23 of 23
(437 Views)
