Seven segment led display with arduino pin configurations
iam new here.. i am trying to dipaly a numbers on led seven segment display. but i dont know how to cinfigure pin numbers with arduino examples...
can anyon eexplain the pin configuration in sevensegment led.
Message 1 of 11
(3,861 Views)
How is your question related to LabVIEW? Shouldn't you post to an arduino forum?
Message 2 of 11
(3,857 Views)
hi, Dennis_Knutson
thanks for the  reply...
iam using the arduino uno board in labview interface. i think this is the place where i can ask  for help. as i told before iam new here. if it is not the right place please suggest me where i can ask.
Message 3 of 11
(3,850 Views)
From your question, it seems you have a question regarding connecting some hardware to the arduino and not at all related to LabVIEW.
Message 4 of 11
(3,844 Views)
i want to connect a hardware as specified in a labview example for arduino interface. in labview they are given the example. and i dont understand how to connect the sevensegment led pins to the arduino as stated in labvie-arduino example.
Message 5 of 11
(3,834 Views)
I have no idea what example you are referring to since you did not provide a link. If it's from the arduino board, you should also know that questions should be posted there. Physical connections will depend on your c code and not the LabVIEW code.
Message 6 of 11
(3,820 Views)
I see a breadboard with a display plugged in and wires from the arduino to the breadboard. Isn't that all the information you need? Of not, you should comment on that page.
Message 8 of 11
(3,806 Views)
Hi anilkun,
in the linked example you see that picture. It shows all the needed wires to connect Arduino with 7segment LED.
What else do you need?
Message 9 of 11
(3,802 Views)
hi GerdW,
thankyou for reply,
in the diagram  connections are showing for common anode seven segment led. iam actually using the common cathode sevensegment led. so i got a problem.
and i want to know which pin is connected to the which led in the diagram. so it might be easy to configure them manually.
Message 10 of 11
(3,792 Views)
