Sigmoid Function for a waveform chart that plots calculated data
I want to add a sigmoid function to my waveform chart. Right now when I increase the throttle the chart shows that the amplitude changes to the new value straight away without  a delay. So I want to implement a sigmoid function that takes me from the initial value to the final value with a smooth S curve implemented. Is there any way to do this?
Message 1 of 8
(713 Views)
Hi AJ,
Yes, sure!
Write down the math on a sheet of paper, then implement the formula in LabVIEW!
Message 2 of 8
(689 Views)
The issue is lets say I use y=1/(1+e^x) the x is a time value that is a part of the waveform chart rather than be in input so I am finding it difficult to implement this? I hope that makes sense
Any solutions to this?
Message 3 of 8
(680 Views)
Hi AJ,
"Time" is not a "part" of the chart...
As you run the code inside a loop: how much time does the loop need for one iteration?
"x" will be the same as "ierations * time_per_iteration"!
Or you simply determine the time difference between start of loop and current time...
Message 4 of 8
(673 Views)
All I need is one iteration per loop
Message 5 of 8
(663 Views)
do you have an example on how to do this please?
Message 6 of 8
(662 Views)
Accepted by AJcpt
Maybe all you need is an exponential filter.
The entire "filter" can easily be wrapped into a subVI. An example for multiple channels can be found here, but you could easy create a VIM that accepts scalars and arrays.
Message 7 of 8
(638 Views)
@altenbach wrote:
... but you could easy create a VIM that accepts scalars and arrays.
Here's how that could look like:
Message 8 of 8
(619 Views)
