Simple problem with a square wave and a boolean LED
Hi Asrih,
so you read my pm and didn't help me... thnx
I don't react on PMs: When you have questions on your topic then you should post in your thread!
You can even bump your thread after waiting for some amount of time!
But creating a new thread for the same problem is the worst you could do then…
Message 11 of 13
(1,367 Views)
Accepted by topic author N.Asrih
@N.Asrih wrote:
im sorry but i dont understand what you did there, where is the LED and the square wave
The square wave is the Raw signal while the LED is the Held.  The idea is to use the Elapsed Time to state when the raw signal has been low for 1 second.  So I reset the timer whenever the signal is high and use the inverse of Time Elapsed? to hold the LED on.
The setting of the Set Start Time is just there to make the Elapsed Time be a TRUE when the program starts up, therefore making the LED Off.
GCentral
Message 12 of 13
(1,358 Views)
Hi again Asrih,
Here's a version that should open on your 2014 LabVIEW.
Let me know if don't understand what I'm doing or you get stuck on anything.
Cheers,
NI-Mikko
Message 13 of 13
(1,350 Views)
