SpreadsheetToArray
Hello i need help with spreadsheet to array i recive data from serial and i wanna use function spreadsheet to array to have all values in array instead of string but i lose floating points in the process but before that function it is all okay i tried to change represatation of array display but it doesnt work
Message 1 of 9
(852 Views)
Try changing the format string from %g to %f.
Message 2 of 9
(835 Views)
If your data is separated by commas all you need to do is this:
=== Engineer Ambiguously ===
Message 3 of 9
(825 Views)
i tried that also didnt work i also tried setting %5.3f to display 3 floating point numbers but also didnt work
Message 4 of 9
(823 Views)
Post your code and a sample of the data string you are receiving.
Message 5 of 9
(815 Views)
Are you from Germany or another region that uses a decimal comma as default decimal character?
Rolf Kalbermatter
My Blog
Message 6 of 9
(777 Views)
What does that have to do with a manure spreader?
Message 7 of 9
(731 Views)
Accepted by Adweqweq
maybe try to set %.;%f
Message 8 of 9
(711 Views)
Thank you very much brudka_kotlet_cardinale this worked for me !
Message 9 of 9
(700 Views)
