Starting/ending two digital output signals with finite samples exactly at the same time
Accepted by topic author ecafer
The main problem is that you're ignoring the advice both GerdW and I gave that you MUST put BOTH digital lines in the SAME task.  There's only one hardware timing subsystem available for DO, any digital signals that you want to generate with clock-based timing must be in the one task that defines the timing.
Instead of 2 separate tasks, put both lines in one task and define your digital waveform to include both lines.
There aren't useful default values in your controls to determine whether you're also being careful to stagger your clock and data transitions so that your data is stable when the active clock edge arrives.  But that'll likely be pretty important too.
-Kevin P
Message 11 of 11
(225 Views)
