Stepper Motor speed control
Hi guys,
Iam planning to use NI USB 6001 card for controlling speed of my stepper motor using a stepper drive. I have looked into some forums and it says USB 6001 can provide only constant PWM, so  the speed will remain constant only. Can anyone here help me ,to achieve speed control of stepper motor using USB 6001 or suggest any other NI card for achieving this requirement?.
(724 Views)
Hi Justin10
I guess, this article can help you find appropriate information in this case. Here is hardware that you can use to achieve desired results.
Regards)
________
Best way to thank is to give Kudos / Mark as a solution.
(656 Views)
