Synchronize PXI-6143 and PXI-5761 and PXI-6581 via PXI_Trig0
How I can send a Trigger on PXI_Trig0 in order to start synchronized acquisition with PXI-6143, PXI-5761 and PXI-6581. I think the PXI-6143 should be the master, but how to send the trigger from the 6143 to other card ?
Regards Marc
(2,428 Views)
I think this example will help you synchronize your boards.
https://decibel.ni.com/content/docs/DOC-2340
(2,391 Views)
Hi Benoit,
Thanks for your answer, I have another question and is about the exemple :
How can I put the 10 MHz of the PXI in the sample clock, in order to have the same clock for the DAQ cards and for the FPGA cards ?
Regards.
(2,371 Views)
