This cluster looks like an error cluster, but it's not
Created a new cluster containing a pass/fail boolean, an integer for "counts", and a short calibration string.  Saved this into a typedef'd cluster, dropped it on my block diagram, and it shows up as the mustard-colored error cluster! Smiley Frustrated
Any way to make this not look like an error cluster on the block diagram?
Adding another object in the typedef and making it invisible is kind of an ugly hack, but it does turn the object string-pink.
Message 1 of 8
(2,716 Views)
Accepted by topic author SnowMule
Reorder the elements.
Right click on the cluster in the type def, select "Reorder Controls in Cluster", and click on the elements in a any order other than, bool, int, string.
Message 2 of 8
(2,709 Views)
Making your counts U32 instead of I32 might work.
Message 3 of 8
(2,695 Views)
If a cluster has three elements, and those element data types are (in order) boolean, I32, and string, then it will get drawn like an error cluster.  Change anything about the cluster to *not* fit those criteria and it will go back to being drawn like a regular cluster.
Funny thing about it being specific to data type is that if your cluster has a boolean, an I32, and a tree control, it will get drawn like an error cluster.  😉
Message 4 of 8
(2,689 Views)
... so the tree is just a string as far as LV is concerned.
Ben
Message 5 of 8
(2,679 Views)
The tree has either a scalar string data type, or an array of strings data type, depending on how it's configured.
Message 6 of 8
(2,671 Views)
Smiley Happy That's the reason I asked here, knew there'd be some simple solution to the problem.
That worked too.  From the string-number conversion in the root VI that actually gets that data, I'd have to cast that to an I32 instead of leaving it as the output's U32.  Not a big deal to do, but since this VI is used elsewhere in other projects I'll just leave it the way it is and change the control order.
Message 7 of 8
(2,635 Views)
The error cluster is sooo 1990s. It needs to be a class.
LabVIEW 2012
Message 8 of 8
(2,629 Views)
