Time column is not generated in Write to Measure file
Hi Members,
I am using Write to Measure (for excel file generation), in which input data from DAQ is loaded, but the time column shows zeros.
How can I resolve this problem? seems like I need to add an additional array of time data (someone please guide).
Thanks and regards
(1,813 Views)
Hi afa,
don't mix up "standard" datatypes (like your sample arrays) with ExpressVIs and their DDT wires.
For more help you should attach your VI, because we cannot debug/edit images with LabVIEW!
(1,804 Views)
Hello, here is the Vi file
(1,800 Views)
Hi I have attached the VI. I think after acquiring the signal. I am applying some basic mathematical operations, due to this, timestamp information is removed.
But for each sample loaded in excel file, I have to show the time as well.
Please help, if possible.
thanks
(1,749 Views)
