07-31-2008 05:23 AM - edited 07-31-2008 05:26 AM
Hello All,
I have LabView 8.5.1, Touch Panel module 8.5, ActiveSync 4.2.0.
Nowadays, I work with Toradex equipment :
-Computer Board: Orchid ( http://www.toradex.com/e/orchid.php )
-Computer Module based on Marvell Xscale PXA320 ( http://www.toradex.com/e/colibri_pxa320.php )
-With WinCE 5.0
When, I connect up my Computer Board in the PC with USB, ActiveSync detect it automatically.
But, when I create a VI with the Touch Panel module and I Run it, I had the following message:
"Error - Unable to run the application on the remote device.
CreateProcess failed with error code = 126
Possible reasons:
The application does nor exist on the remote device.
Another application with the same name is already running.
The application is not compatible with the operating system of the device.
Closing connection ...
Done"
And, when I try to Run the application on the Computer Board, I had the following message:
"Cannot find Project.exe (or one of its components).
Make sure the path and filename are correct and that all the required libraries are available."
Ismail HIMDI
08-04-2008 03:59 AM - edited 08-04-2008 03:59 AM
Hello Ismail.
Could you say us if MAX recognizes your devices?
Thanks, regards.
Romain D.
National Instruments France
11-18-2008 08:40 AM
Hola...
Yo estoy programando una PDA, iPAQ 214 que soporta USB Host, con tarjeta NI USB-6009 y tengo la misma descripción del error aunque con código de error 30123
"Error - Unable to run the application on the remote device.CreateProcess failed with error code =30123
Possible reasons:The application does nor exist on the remote device.Another application with the same name is already running.The application is not compatible with the operating system of the device.Closing connection ...Done"
Estoy utilizando Ni-DAQmxBase3.1 con LabVIEW8.5.1 Windows XP. ejecuté el FWUpdate en C:\Archivos de programa\National Instruments\NI-DAQmx Base\bin
"NI-DAQmxBase List Device" lo reconoce y el MAX también.
11-28-2008 04:06 AM
02-10-2009 04:46 AM
Hi Ismail
I work for Bluechips Microhouse Thailand, a Toradex partner that is producing their hardware (incuding Orchid). Toradex Orchid default image distributed by them (WinCE 5.0 Core License) can not run Labview. You will need a WinCE5 Pro licence for it, that you can buy from Toradex, from Microsoft or from us. Some OS components required by LV are not part of the Microsoft WinCE50 Core Licensing scheme, I am not sure which components are needed (I am not a Labview geek), but SYSGEN_AYGSHELL and SYSGEN_WEBVIEW are two of them and both are Pro.
Even Pro images distributed by us with our XPosure series of terminals in the past (using Toradex PXA 270 and 320 CPU modules) without this components could not run LV.
