06-21-2013 01:52 PM
Well, I thought these controls were numerics. If they are strings, you can set them to "update while typing" and you should have no problems.
06-21-2013 02:00 PM
Unfortunately the actual program uses all different types, including DAQmx tasks and typedef'd enums, so that's only a partial solution. That said, I didn't know such a thing existed. I'll keep that in mind for future projects.
06-21-2013 02:03 PM
Success!
Adding a shift register to hold the "current" value of the tree did the trick! Hopefully this can be useful to someone else looking to make a more flexible configuration VI.
06-21-2013 02:11 PM
If I can actually get the VI to post...nope have to change the extention to a txt. Change it back to VI after downloading it.
The shift register works like a charm. I went ahead and did a few other cleanups while I was at it.
