Trigger line usage on the cDAQ-9181 with a cRIO-9401 module
Yes, I am receiving error -200254 when using DAQmx Write (Digital 1D Bool NChan 1Samp).vi.
Message 11 of 14
(1,351 Views)
Hi Chris,
Sorry, I believe I was mistaken earlier. The four lines you are writing to should each be considered a separate channel. So, try changing the line grouping constant to 'one channel for each line'.
Also, have you been able to isolate whether the error is occurring in the first or second instance of DAQmx Write? You may want to explicitly start the task before the first write operation. Doing so is typically considered good programming practice when working with data acquisition.
Tom D.
Staff Software Engineer
NI
Message 12 of 14
(1,329 Views)
Tom, I think the attached is what you were suggesting. I will try this out shortly and get back to you. Thank you again for your assistance.
Message 13 of 14
(1,317 Views)
Accepted by topic author Chris_12345
Thank you to Jon Frantz at NI for providing me with a solution to this issue. See attached code.
Message 14 of 14
(1,288 Views)
