Turn OFF LEDs in case structure
Is there an opportunity to do this with like 10 leds somehow?
Message 11 of 15
(371 Views)
Hi Felix,
Yes.
Message 12 of 15
(363 Views)
Hi Gerd,
thanks for your quick answer, maybe you can help me with my original problem as well.
I have a case  structure based on numerics and i want to turn on and of the led which is inside the structure.
At the moment the LED turns on but unfortunately doesnt turn off. Your advise for the one LED didnt work as well as i though it should there.
Best regards
Felix
Message 13 of 15
(359 Views)
Hi Felix,
Why do you convert the string to a float value? The case structure only accepts integers, so your conversion should be to integer value!
The LED only turns ON because that's all you do. I don't see where you try to switch the LED OFF...
Message 14 of 15
(351 Views)
Hi Gerd,
The string is given by a turbine i control via Labview und the case structure works as it should.
Fixed my problem, your first advise was the right one, i just messed up
Kind regards
Felix
Message 15 of 15
(326 Views)
