Unbundling an array of doubles
Hi Forum,
I need to measure current from 20 channels so I combined the values of the 20 shared variables (one from each channel) into an array form and then send to a network variable for transferring data from A.vi to B.vi. And then on B.vi, I use "unbundle by name" to unbundle the cluster back into the twenty individual values and indicate them one by one.
My question is, how can I figure out which value is which out of the twenty variables? I connected the 20 shared variables to the array in a particular sequence and when i use "unbundle by name" would the sequence be consistent?
I have attached a screenshot just to explain things better.
Any help is greatly appreciated!!
Batistuta002
(2,387 Views)
Accepted by topic author Batistuta002
Yes, it is the same as the first element of the array.
But you shouldn't be converting to a cluster than unbundling.  That is a Rube Goldberg.
You should be using Index Array to get the individual elements.
(2,383 Views)
Thanks Ravens Fan!
So if I want to use Index array, then i would need to assign index numbers to each elements when I combined the 20 values from the variables to an array right? If I don't, does LV assign 0 to 19 for the 20 elements from top to bottom automatically? Sorry that I cannot verify this by myself as I can't test it out using actual measurement because of hardware issues.
(2,376 Views)
Yes. It will automatically assign it the indices 0 to 19 when you drag down the bottom of the Index Array function.  No need to wire up all of those constants.
The first index always defaults to 0 if nothing is wired to it, and an index always defaults to the index value of the one before it +1 if nothing is wired to it.
(2,373 Views)
