Understanding "Registration Method" in Golden Template Comparison
Hi to all.
I have an application which I do golden template comparison.
The probloem is that sometimes the object inspection in image inspection is a little smaller or bigger (becouse photo taken not because of object).
So for that reason before golden template I use geometric pattern matching to pass output orientation and scale to input Alignment in Golden Template.
Now I would like to understand Registration Method input in Golde Template Comparison, changing this input application would work better in that case??
Thanks a lot
Message 1 of 1
(2,116 Views)
