Unflatten From String causes runtime error in LV2009
I found this error when trying suggestions made in this thread.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=458335
Unflaten from string causes runtime Error 74 possible reason(s) Memory or data structure corrupt.
=== Engineer Ambiguously ===
(2,933 Views)
Of course you are getting the error. The data types are inconsistent. You convert the cluster to an array. You then define the type of flattened string as a cluster. Either don't convert to an array or define the data type as an of paths. Look again at the examples in that post.
(2,924 Views)
