Unused IP address still showing up on 'Find.vi' Systems
I have a bunch of cRIOs on my local subnet.  I'm using 'Find.vi' Systems instance to find all of them from my host application.
I have had the cRIO IP addresses statically set to certain values for a few weeks.  I programmatically changed one's IP addresses from the host.
However, when I do another 'Find.vi', the old address of the one I changed shows up in the list along with the new address.  It almost seems like the addresses I have had them set to for a long time stick, but the new addresses don't.  For example, I had one set to 192.168.1.204 for several weeks.  I change it to 192.168.1.205 and both 192.168.1.204 and 192.168.1.205 show up in the list.  When I change it back to ...204, only ...204 shows up in the list.
Is there some cache that needs to be cleared to stop this from happening?  I've attached a screenshot of how I'm doing the 'Find'.
Thanks!
tourofmars
(2,532 Views)
What happens when you make the include cached results to none?
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,517 Views)
I am not sure how the Find.vi looks for addresses but it is possible that it may use a name lookup on the network and teh old addresses may be cached in the name server.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,516 Views)
Same results when I set it to 'None'.  I'm looking directly for IP's.  The two IP addresses show up for the same MAC address, which I thought was strange.  See the attached...
(2,507 Views)
The old address is cached in either the name sertver or a network device ARP table.
Mark Yedinak
LabVIEW Champion
(2,503 Views)
