Update old Labview project Dependencies to build application
I need update an old  Labview project (Labview 2011) to Labview 2023, and build application to end user.
From "Build Specifications", the "Startup" VIs contains some deprecated subVi (in vi.lib\utility\file.llb).
I update those SubVI to latest, and the startup VI works fine. But when I check with the files in Dependencies,
it still contains those deprecated subVi, and without added new subVi.
When I build application, it will use the Dependencies files to build application?
How can I update Dependencies files content after I modify "Startup" Vi?
(841 Views)
Hi Rabbit,
Why do you need to update those dependencies?
Is the VI not executable without changing them?
Can you share the old "startup VI" (or the whole project)?
(815 Views)
Hi GerdW,
After I shutdown Labview and restart Labview, it is showing correctly now,  the updated Vi is in the Dependencies, and the deprecated subVi is not there.
(757 Views)
