VI of the Day (9/4/2009)
Are you using the right frequency? Try this:
middlec
That should be middle C.
Message 11 of 31
(1,505 Views)
nope I tried it and still no noise
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 12 of 31
(1,501 Views)
Name that tune.  Not enough time to tweak it (and my pitch is terrible), but I think it is recognizable.
Note this works just fine for me on LV8.2.1 with XP or Vista.  Be sure to disable the system beep.
Message 13 of 31
(1,488 Views)
Montreux is a hint 😉
Message 14 of 31
(1,466 Views)
Now all we need is a reentrant beep.vi so we can do polyphonics. 😄
Message 15 of 31
(1,460 Views)
The mystery tune is pretty easy for those of us that went to HS in the 70s - nice job.
Below is a simple alarm vi that toggles between the system alert and the synchronous beep modes. I think the combination makes a reasonably good alarm sound. If you control the on/off with a queue, you can set up a very simple application wide alarm.
steve
www.ashfordsolutions.com
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 16 of 31
(1,442 Views)
Does your computer beep when you boot it up? I had a machine in which the internal speakers were disconnected, so I got no sound in that machine.
Message 17 of 31
(1,441 Views)
I just restarted my computer and no beep..... so I don't know how it was diconnected because it is a laptop and I havn't done anything with it hardware wise or software wise really.....
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 18 of 31
(1,438 Views)
Well... I've not tried the VI on my laptop. I'm not sure of how laptops are built inside. Usually the desktop CPUs are connected to a small speaker internally, which gives the beep...
Come to think of it, I don't recall my laptop beeping during boot up either, which means that beep.vi shouldn't work on it too, if my hunch is correct. I'll confirm and get back to you.
Message 19 of 31
(1,436 Views)
Sounds good I would like to mess with the beep.vi but never have had the opportunity so I normally use the lvsound.llb
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 20 of 31
(1,434 Views)
