VIs running slow after Developer Suite installation
Up until yesterday, I was running a version of LabVIEW 8.5 that I had downloaded from the NI website, and then activated using the serial number.
Yesterday, I got around to installing the full NI Developer Suite (including LabVIEW 8.6 and a load of extra modules/toolkits), from the supplied DVDs.
Since then, my VIs seem to be running a lot slower.
Is there something that might have started running in the background slowing things down, since the Dev Suite installation?  Is there a known issue in the speed of v8.6 compared to v8.5?
Dan
CLD
(2,496 Views)
Hi Dan,
"seem to be running slower" is not very descriptive...
- Measured speed?
- What vi? Calculations? DAQ? Port access?
- Checked taskmanager? CPU load?
For me LV8.6 has about the same speed as LV8.5. LV2009 is sometimes faster (~7% for heavy memory access routines...).
(2,485 Views)
Hi there
I have several LV versions installed, including 8.5.1 and 8.6.1, and as far as i know there are no issues regarding slowing down VIs.
1. Take a look at the projects "Files" tab page to check wether there are still some 8.5 VIs linked to your code
2. If you are absolutely sure there are no 8.5 VIs linked make a mass compile of your project (Tools->Advanced->Mass compile)
But maybe it's something simple like a highlighted execution in one of your sub VIs.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,483 Views)
Did you try monitoring using VI profiler?
Tools>Profile>Performance and Memory
Also, I believe the loading time may have increased in your case, because of LV loading extra modules you have installed.
I experience this during my first "search" functionality in LV since I have lots of modules installed.
Cheers!
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(2,482 Views)
