Voltage change for QANSER QNET P&D board
Hello.
I'm using ELVIS II+ with a QNET physics and dynamics board, I have the "quick start" LV-code (VI), but I can't initialize the ports to change the voltage for the electromagnets, or for some other reason change the voltage. As far as I know, the electromagnets used operate on a voltage of 0-6V.
Now I can turn the electromagnets on and off, no error occurs on the AO Voltage block (other implementations did, so I used this), but changing the value fed to the Analog DBL does not change the voltage. How can I change this voltage, and what could be the error due to which this does not happen?
In the attached file, I just added a bottom branch with AO Voltage and all the other blocks in the branch, and this solution, judging by the files I have, should work, so I guess the problem is in specifying ports or something like that?
Message 1 of 1
(527 Views)
