When streaming data with modbus the reading rate returns to a slow rate after update of baudrate.
I am having problems with streaming data with the attached VI. It concerns the inner FOR loop in frame 7 of the flat sequence. The times between readings were more than the specified 100ms timer so I upped the buad rate from 9600 to 19200 this improved the timing down to about 125ms. But after a few runs the time increased again to about 800ms. I updated to 38400 and the performance was perfect but then after starting the VI a couple of times it went back to roughly 800ms again. I suspect this is something to do with Visa because I have found generally that if you stop a VI when it is running you get unusual com port addresses in the comport list which when cleared gets rid of communications problems. But clearing those in this case doesnt help.
I have the same issue on another similar set up and changing the modbus client pc, also with a new installation of Labview community, doesnt help either.
I hope you can help.
(142 Views)
Please share your VI, it may also be with how you implemented the code inside the loop causing it to slow down over time, a common mistake is accumulating data over time in array and writing to file in the same loop as the reading part.
Santhosh
Soliton Technologies
(140 Views)
Sorry I attached my VIs before but didnt upload
(130 Views)
Accepted by topic author EdHarris
The  solution is here. Not eally a solution more like an outcome.
What-could-change-after-a-baud-rate-increase-to-slow-down-serial
(11 Views)
