Where find and maxon epos driver vi's? And how install them?
I am preparing a labview 2015 development environment for a colleague and I need to install support for Maxon motor controller, EPOS.
Some hints to what I need:
C:\Program Files\National Instruments\LabVIEW 2015\instr.lib\maxon EPOS
C:\Program Files\National Instruments\LabVIEW 2015\instr.lib\maxon EPOS\EPOSLibrary.llb\Initialize.vi
 C:\Program Files\National Instruments\LabVIEW 2015\instr.lib\maxon EPOS\EPOSLibrary.llb\VCS Set Operation Mode.vi
EPOSLibrary.llb
I also get an error code saying that EPOSCmd64.dll is not working on this system (dev system is 32 bit windows 10), see attacment. So I need the 32bit version of this file.
I have no earlier experience with finding these drivers/vi's. My collegue says he has the installer somewhere, but I guess I can find it from maxon or National instruments?
Ola
(3,619 Views)
I found a temporary solution, I just copied the EPOS (under .../instr.lib/ ) folder from a working installation.
But I like to find the drivers from maxon, maybe they have updated them. We have some issues with the current version!
(3,584 Views)
How about searching for "EPOS" in the Instruments Driver Network
Not sure if it is the same library as yours but it is the only one I found.
Regards, Jens
Kudos are welcome...
(3,580 Views)
Thanks Jens!
I found one also, (Maxon Motor maxepos2 ) seems to be from 2013. For labview 2010. "Not supported" etc. The contents seems to be correct, I am not sure if it the latest one though!
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7D860A61EC12469DE04400144F1EF8...
(3,577 Views)
