Why Does This Throw Error 1162?
This bug has been driving me nuts.  I've trimmed the code down to a tiny piece that fails.
This throws error 1162:
No error here:
Why do I get an error when I pass the empty string through a cluster?
Message 1 of 9
(3,215 Views)
While I can't answer your question, I can confirm I get the same results on my LV2018/32 bit installation.
The weird thing is... if you delete the text "APP_FILE" in the String constant inside the Cluster constant, it works. You can replace it with other text and it fails. Looks like a bug to me. I wonder if it has something to do with the compiler doing some constant folding shenanigans?
Message 2 of 9
(3,194 Views)
I was also able to reproduce the behavior in 2019 and found the same pattern described in the previous post: if the string constant in the cluster is empty, then there's no error.
I have filed Bug #993017 for the appropriate team to further investigate and follow-up.
Thanks!
Message 3 of 9
(3,186 Views)
Accepted by topic author paul_cardinale
I've discovered that in my little snippet, I can fix the problem with either this:
or this:
but neither fixes the problem in my real app.  In order to fix it in my real app, I have to do this:
Message 4 of 9
(3,180 Views)
And now in my main app, it's broken again.  The "Always copy" and "Type cast" functions are no longer effective.
Message 5 of 9
(3,078 Views)
No error with the following,
You can always try another way to make a copy with this
(Note your snippet with the typecast and always copy did not produce an error.)
mcduff
Message 6 of 9
(3,066 Views)
This works.  You've got to trick the compiler into not inlining stuff.
Message 7 of 9
(3,059 Views)
And now that doesn't work anymore.
Message 8 of 9
(3,039 Views)
Whether or not this bug is manifest seems to depend on whether the block diagram that owns "Get Menu Item Info" has ever been opened.
Message 9 of 9
(3,033 Views)
