Why is one of my 4 5893 Modules not working correctly?
This is my HW and SW configuration:
LabView 2013 SP1
1x cRIO 9076
4x NI 9853 CAN Modules
CAN0 - 1000 kbps, Input Timeout=0, OutputTimeOut=10000, Module Clock: 20MHz
CAN1 - 500 kbps, Input Timeout=0, OutputTimeOut=10000, Module Clock: 20MHz
I have been working on a program for a test system, where each 9853 Module controls two devices (CAN0 and CAN1), the same type of systems will be controlled by the other 3 9853 Modules in parallel.
So basicaly, I use exactly the same Functions for every module. Until now, everything has been working correctly on module 1, but now that I started testing all other modules I have the problem that Module 3/CAN0 does not read the information correctly.
While looking at the FPGA frontpanel, i see that every 10000ms one value is read, but only on this ONE module (CAN frames are sent every 1ms from my device)
I tested the HW itself using the examples included and it works correctly, the only difference is that the example only used 2 Modules, one to send data and one to recieve it.
I am including my FPGA program as a picture, I realy do not think this is a problem with my RT SW, because all other modules work correctly. Basicaly, my FPGA SW only reads the CAN Modules and puts the information in a FIFO, if there is an error (no information) it will loop once more and check again.
Thanks for your help
(2,564 Views)
short update, after looking into the problem I noticed that the Module sends this error:
Error 65539 occurred at an unidentified location
Possible reason(s):
CompactRIO:  (Hex 0x10003) The input function missed one or more data points. Make sure the loop can execute as fast as the module data rate.
(2,539 Views)
Accepted by topic author Mex_J
I have solved the problem, it was a configuration error from my side.
The input timeout for Module3 CAN1 was configured as 10000ms and NOT as 0ms as I thought ! , so this was making my Read Loop for DUT3 run only every 10000ms.
(2,517 Views)
