Why is this "Operation not valid for strict type definition instance"?
This is sort of a follow-up to that message where I described what I think is a bug which does not allow using the "IndexVals" property of a Strict Typed Def array in "Write" mode (at least without jumping through a few hoops).
In short, if I take a reference to a Strict Typed Def array and use the "IndexVals" Property in "Write" mode in a SubVI (which I can access without gimmick, interestingly), this throws an error 1082, with the following Explanation:
LabVIEW: Operation not valid for strict type definition instance. Property Name: Index Values
I have searched for both the error code and the error message and found these threads:
http://forums.ni.com/t5/LabVIEW/Error-1082-when-setting-Strings-property-of-a-menu-ring-control/m-p/...
http://forums.ni.com/t5/LabVIEW/error-1082-with-active-cursor/m-p/146497
http://forums.ni.com/t5/LabVIEW/Why-does-a-strictly-Typed-Control-cause-error-1082/m-p/125418
It seems to have been diagnosed as a bug (but without a CAR) at least since 2004, but apparently this is still an issue in LV 2013 SP1 (which I tested it in).
Nothing about Strict Typed Def throwing an error with this property in the Help.
Time to kudo this idea... and fix this bug!
(4,304 Views)
Hi X,
I think Paul may have answered this question in the message this post is referencing. Part of the functionality of a strict type def is restricting what you can change.
http://forums.ni.com/t5/LabVIEW/Array-Index-Values-Property-Read-Only/m-p/3112536#M892653
https://www.linkedin.com/in/trentweaver
(4,243 Views)
I think Hoovahh in that thread has objected to that answer better than I could have.
Now, it is perfectly fine for NI to stand their ground but it doesn't make any of the things I have reported consistant for that reason.
(4,232 Views)
Hi X,
So we dug a little deeper into this and couldn't find a CAR filed for this specific issue. A new CAR was created (#512512) and R&D will investigate this further.
You can monitor the list of known issues and bug fixes at links such as these:
https://www.ni.com/en/support/documentation/bugs/14/labview-2014-and-2014-sp1-known-issues.html
https://www.ni.com/en/support/documentation/bugs/14/labview-2014-bug-fixes.html
Thanks for bringing this to our attention!
(4,196 Views)
