05-02-2015 11:03 PM
Why Configure the Application Web Server is locked? .....................why can't click to open it.....................
Solved! Go to Solution.
05-04-2015 04:56 PM
Hi aqeelfarooq96,
Make sure the NI System Web Server is running in your Windows Services.
Control Panel » Administrative Tools » Services
If the NI System Web Server is not running then you will not be able to configure the Application Web Server.
05-05-2015 07:32 AM
Thanx mate that you spend some of your time in solving my problem.............Re-installing has solved my problem..........you are right that services are off before re-installation but afterward services would restore ..............
