Windows 10 LV2014 and FPGA/RT problems?
http://www.ni.com/white-paper/52818/en/ says for FPGA and RealTime I need Labview 15 minimum, of better, its certified for that. Did anyone run into trouble with Windows 10?
I am facing issues with finding cmodules once I removed them from a project file. Labview as such is running and I can run existing projects including deploying vis onto the cRio.
Cheers,
Steffen01
(2,393 Views)
That white paper only states that LabVIEW 2015 and above have been tested with Windows 10 and thus are certified as working with that OS. As LabVIEW 2014 and its module have not been tested, we cannot say anything about it. Might be working... or not !
CLAMaxime -- Kudos are a great way to say thank you
(2,359 Views)
there was something on silverlight. Is this how they access xml files?
There was something in the forum where someone reverted back to Window 7 and then it was working.
I will try, no time to loose. Seems I am in for a complete re install anyway
(2,355 Views)
